laser as heat source
Can I use laser as a heat source to heat up some medium?
RE: laser as heat source
I would stick with conventional means such as water thru a heater etc... which you could control easier.
I hope this helps. Also this is only my opinion you may find someone out there that thinks or has done otherwise.
Good Luck!!
Mark
I want clarification for this. If i use laser as a heat source, for modeling in FEM, how can i convert the laser power as heatflux to apply in a particular element of FEM mesh.
Please clarify this
with regards
sivakumar
