spool to a dynamically created file
I would like to spool a SQL result to a file.  But, I want the file to change depending on what the user enters at a prompt.  The problem I am having is that now I want part of my file name to be built depending on what the user enters.
For example, I want the file name to contain a year and some text.  The text is conditional: if the user enters 1, then 'PNC'.  If the user enters 2, then 'LAH' else 'NULL'.
ACCEPT yr PROMPT 'Enter Year: '
ACCEPT instype PROMPT 'Ins Type: '
DEFINE underscore = '_'
DEFINE ext = '.csv'
DEFINE report = 'CustomReports\D3F_&instype&underscore&yr&ext'
SPOOL &report
I do not really want to spool to a file called 'CustomReports\D3F_2_2002.csv'
Instead, I would rather spool to a file called 'CustomReports\D3F_LAH_2002.csv'
I tried using PL/SQL to build my file name but I am still having trouble.
Does anyone have any ideas?
Thanks in advance.
