How to draw other analytical sketches?
Is it possible in the solidworks sketcher to draw hyperbolas, cubic, and other higher order polynomials without using splines?
RE: How to draw other analytical sketches?
You can do an elipse, but I'd bet it's not an exact, but an approximate elipse.
You're basically SOL with SolidWorks - as far as I know.
I'm sure there's something else out there that can do what you want at a fraction of the $$$.
Consume mass quantities...
tatedeleteredj@usfilter.com
I was aware of the ellipses, circles, parabolas, and splines. However, other curves have other properties such that aren't exactly duplicated by splines.
Not seeing the other functions on the toolbar I should have asked if it is possible to use any API features to generate non spline analytical curves.
You can create a curve through free points using Excel and the coordinate system. Is that what your looking for? I believe it still uses a spline to make it. You may try using 3D sketches also.
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt, always check the help*
There is a macro on Matt Lombard's page:
http://www.frontiernet.net/~mlombard/
Look under macros for the one that will draw a sketch of an equation.
Will this work?
Ken
