Drawings - Solid Polygons
Does anyone know if it is possible, (and if so how)to create a drawing block that is a polygon with a solid fill? I know its possible to use a dense hatch pattern, but this is a bit messey.
SW 2001+
Any ideas?
thanks in advance
RE: Drawings - Solid Polygons
In SolidWorks 2003, when you do an Insert, Area Hatch there is a switch called SOLID...
I am not sure if SolidWorks 2001Plus has this, but please try.
cheers,
Joseph
