v-belt drive design manual
Where can I find a good comprehensive v-belt drive design manual, perhaps including concepts for active tensioning ?. The major belt manufacturers probably have something like this, but I haven't been able to find it at any Web site.
RE: v-belt drive design manual
Sorry this will not answer your question, but I have a similar problem and I was wondering if you had discovered anything in your searches? I'm trying to find out about the efficiency of the common v-ribbed accessory drive belt. I must say, trying to find solid engineering information about drive belts is quite depressing so far. The SAE site (www.sae.org) has several drive belt items but you don't get to find out if they're talking about what you want to know until *after* you pay. Relatively big bucks in some cases. The summaries are almost useless.
Sympathy and regards,
Dan Babitch
Nothing yet, but I'll be working with two v-belt manufacturers shortly, and I'll let you know what I find out.
John Swanson 11/22/99
MACHINE ELEMENT IN MECHANICAL DESIGN
BY: Robert L. Mott
Adrian
http://www.mech.uwa.edu.au/DANotes/V-belts/home.html
