Plastic Section Modulus
Using limit state design methods, I have come across the need to use Plastic Section Modulus.
This is usually given as the expression S=I x Ymax, where I= Ix or Iy depending on axis you are looking at etc. Ymax is distance from Neutral Axis to outer edge of section.
Does this expression hold true for all symmetrical sections about the axis in question??
RE: Plastic Section Modulus
Here in the uk we call it the section modulus=Z=I/Y and yes it applies to all symmetrical sections as far as I know.
hope this helps
desertfox
The difference is that elastic every part of the section remains below the 0.02% yield region and plastic means some of the material goes beyond this point but the section still holds the load. What i am trying to say is that in plastic design the shape is important and this is allowed for by a shape factor which is different for different geometries. In eleastic design only the I of the section is required. So if you are designing something that will go beyond elastic stress at any point, then its plastic design and shape is important.
There will be no simple relationship between this and the elastic properties of the section.
On the other hand the plastic limit on the beam is when
yield stress=(M/I)*y
which seems to involve the original poster's question. It is entirely general so long as the usual conditions of beam theory are met.
Cheers
Greg Locock
Have got it sorted, the original question related to a design standard NZS 3404 (structural steel, and probably all standards using limit state design) when designing pin connections.
The Plastic modulus in this case turns out to be 1.5 x "elastic modulus" for a solid circular section for this particular standard.
be careful with all these figures: the plastic modulus for a circular section is about 1.7 times the elastic modulus; the ratio is exactly 1.5 for arectangular section.
See the site below under Beams->Sections for values and formulae of plastic moduli for various section shapes.
prex
http://www.xcalcs.com
Online tools for structural design
