Reinforced Masonry Question
In reviewing a set of plans, I ran across this question. The structural engineer had a table that gave the required lap length for reinforcing rods grouted in the cores of the block. At some locations, next to vertical control joints, he calls out #6 rebar with an 8'-2" lap. Why so long? I thought 40 bar diameters was pretty much standard.
Of course, the poor mason that has to do this will have to figure out a real trick. Lifting a 8" or 12" block over the top of the lap bar is no small task. Yes, there are special connectors that can be used, but I just don't see why an 8'-2" lap.
Any enligtening comments?
RE: Reinforced Masonry Question
I'm just glad to be reassured by JAE that I was correct in my calculations/interpretations- I've had to prove it several times over and I still don't think the Architect and Contractor believe me...
