welding .040 thick 316 ss
flat plates 040 316 ss 6" X 6".....have to butt weld with fusion technique..................have machine as low as it will go, lincoln square wave 175 with argon and 1/16th tungsten.....problem is not heat.........but blowing through.
have clamped flat bar below seam for heat sink.....still blow through, not as much though.
material is actually a somewhat dimpled material so food product passing over it meets less resistance.
have been using .023 304 mig wire as a filler rod when necessary.
any suggestions other than 'keep plugging away'?
RE: welding .040 thick 316 ss
This thickness is often welded without backing in the aerospace/aircraft industries, I suspect there maybe other factors (such as the deformations) in the material. The material may be thinner at the areas of deformation.
Texured materials or materials that have complex shapes (i.e.: wrinkle belly) are often difficult to weld due to the thinner areas that have been hot/cold worked during the material processing.
