Max. backpressure conventional PSV for fire case
API RP520 part I, section 3.3.3.1.3 (page 36) reads:
"In a conventional pressure relief valve application, built-up backpressure should not exceed 10% of the set pressure at 10% allowable overpressure. A higher maximum allowable built-up backpressure may be used for allowable overpressures greater than 10% provided the built-up backpressure does not exceed the allowable overpressure"
It is my interpretation that when we have a PSV for fire case only, I can use a conventional relief valve provided that the built-up backpressure stays below 21% of the set pressure. However, the wording "may be used" in the API 520 sounds quite weak to me.
In this particular case we have a relief valve that reliefs directly to atmosphere.
What is your opinion here?
RE: Max. backpressure conventional PSV for fire case
This is my personal opinion.
Built-up back pressure refers to the pressure downstream of the PSV.
Allowable over pressure refers to the pressure upstream of the PSV.
In your case, provided that piping system downstream of the PSV to atm is the same size of PSV flange connection, you should not have any problem. For other applicatiion where the relief discharges tied-into a common header to the flare system, the back pressure should not exceed 10% of the PSV setting otherwise, the PSV relief capacity will required to be derated accordingly.
As for the allowable overpressure in the equipment/vessel the PSV is protecting, should not exceed 10% of the equipment/vessel design pressure on block outlet case or other process upset case. However on fire case, the max allowable overpressure may exceed the design pressure by 21%.
Hope the above clear thing up.
besides i dont think u will want to increase your back pressure on the psv... than needed since higher back pressures mean a correction in the psv relief rate.
Point is with a conventional relief valve, the backpressure reduces the lift force that is holding the valve open. When there is a fire, pressure in the vessel increases until relief valve setpressure. At this pressure the relief valve starts to open. When the fire is not extinguished, pressure may increase inside the vessel to 1.21 times the relief valve set pressure (assuming the relief valve is correctly sized).
If the relief valve pressure increases more than the increase in vessel pressure, this may result in (partly) closing of the valve which reduces the valve capacity and this is of course not exeptable.
For example: if the relief valve set pressure is 10 barg, the allowable overpressure is 2.1 bar. So, I can use a conventional relief valve, provided that pressure drop over the tail-end pipe to atmosphere at max. flowrate is less than 2.1 bar.
In that case the delta P over the relief valve remains at least 10 bar in all circumstances.
If the relief valve backpressure increases more than the increase in vessel pressure, this may result in (partly) closing of the valve which reduces the valve capacity and this is of course not acceptable.
Your interpretation of API is 100% correct and I can't see where the confusion is. Personally, I don't even see the need for interpretation as I think API is quite clear. A conventional valve is dependent on the forces acting on the spring. If you have a greater upstream pressure, then the backpressure at the relief valve can also be greater before the valve tries to close and you loose capacity, period.
A possible reason why the built-up backpressue is high maybe due to a choked flow condition. Said another way, with a given flow and pipe configuration, you may very well have reached critical pressure at a point just near the pipe exit. Therefore, the calculation to determine backpressure at the relief valve outlet flange (you start at the pipe exit and work back) must start with this critical pressure, NOT atmospheric pressure.
If this is for a vessel in europe be aware that the new PED does ONLY allow 10% overpressure no matter what. The API 520 sizing rule for fire is no longer valid in europe. Only 10% overpressure.
Best Regards
Morten
Yes, this is for a vessel in europe. But...
Official Guideline 5/2 (see http://ped.eurodyn.com) reads:
Guideline related to: Annex I Section 2.11.2, Annex I Section 2.12.
Question:In respect of pressure limiting devices, does the PED require that the permitted short duration pressure surge of 1,1 PS be maintained when the equipment is exposed to external fire conditions ?
Answer: The 1,1 PS restriction does not apply to fire.
Reasons: The requirement in Annex I section 2.12 for external fire refers to damage limitation, and does not serve the purpose of pressure limiting device in normal operation.
So we can still use API 520 sizing rule for fire. (The reasons given are a bit strange though...)
In fact, we have used the API sizing rule for fire on several projects that complied to PED. This was accepted by the notified bodies.
I will look further into it.
Best regards
Morten Andersen
2. Ref Sonic Velocity at discharge to atmosphere: If sonic velocity is reached at the discharge, this is INCLUDED as part of the TOTAL VARIABLE backpressure on the valve. For example, if the relief valve is set at 100 psig and the vessel design pressure is 100 psig and the built-up back pressure due to flow (friction) is 5 psig and the pressure at the end to the discharge pipe is 10 psig with 10+5 = 15 psig pressure immediately after relief valve as it enters discharge line (due to sonic conditions being reached) with an atmospheric pressure of 14.7 psia, then the TOTAL VARIABLE backpressure is equal to 5 psi +(24.7-14.7) = 5+10 = 15 psi which is equivalent to 15% backpressure. So a balanced bellows valve is required.
3. Ref Europe vs API: To the best of my knowledge you still consider both 10% and 21 % overpressure based on whether a fire-case is applicable. Unfortunately, I do not have the needed regulations on file to verify this. Allowable accumulation for fire will vary between API, ASME and PIPING regulations, however.
The more you learn, the less you are certain of.
Second, I guess we'll just have to agree to disagree as far as CHD01's point number one goes. Yes, if at the outset it is determined that the variable backpressure exceeds 10% of the set pressure during a non-fire scenario, then the balanced bellows valve must be chosen. However, just for a fire scenario if the variable backpressure exceeds 10% of the set pressure but still remains less than 21%, this should not eliminate the conventional valve from contention (see quote from API in original post).
The allowable variable backpressure is directly related to the allowable overpressure and should not always be assumed to be based on a 10% allowable overpressure (again, see quote from API in original post). Look at the case when you have two or more valves in the same service. You are allowed a 16% overpressure for the same non-fire scenario! In this case, the allowable overpressure in the system is NEVER calculated at 10%. We are dealing with opposing forces on a spring.
Most people just take the API statement of "DO NOT LET THE VARIABLE BACKPRESSURE EXCEED 10% OF THE SET PRESSURE FOR CONVENTIONAL VALVES" without reading further. The use of one or two statements in the Codes and practices do not preclude the need to read and understand the whole thing.
One last thing I have to say on this. No matter what I think or anyone else thinks, each company or institution has their own safety standards (or should). These cannot be any less stringent that given by the applicable Codes but can be more. So, you must always follow what your particular standard is no matter what. If your standard for conventional relief valves is never to allow the variable backpressure to exceed 10% of the set pressure, then so be it and enough said.
Just for the record, I agree with CHD01's second and third points.
I believe earlier versions of API recommended practices used to cite this the same way. However, later versions have changed the language to reflect the original post.
In most cases, vendors stamp relief valve capacities at 10% overpressure which makes sense for the ASME language. But Appendix M is a non-mandatory section and I think would accept further engineering assessment of the guidelines. I think that the analysis of balanced forces on the relief valve disc presented by pleckner is a reasonable engineering assessment to say that allowable backpressure is related to overpressure. So of course this would mean checking the outlet line backpressure for the valve capacity at overpressure.
I would tend to disagree with the arbitrary use of bellows valves though. Bellows valves are inherently less reliable since bellows can fail over time for various reasons. Bellows valves require proper venting of the bonnet to function properly and this can become very difficult when dealing with highly toxic chemicals that would not be suitable for venting to atmosphere. If at all possible, try to design you discharge piping system to preclude the need for bellows type valves as a first choice.
One comment, if I am over 10% I might sometimes stay with a conventional valve for an existing installation. But before doing so, I would insist on recalculating the required orifice size if the Built Up Backpressure exceeded 10% enough that it resulted in a derating of the conventional valve capacity. This is just to be very sure that it did not push us to the next larger orifice size; plus a recalculation of pressure drops for an increased capacity valve. One cannot just assume derating a valve results in an acceptable installation.
* To provide enough force to open a conventional PSV fully we require an inlet pressure 10% above the PSV set pressure. So at the starting point we are already 10% above the vessel design pressure.
* When the conventional PSV opens and thus fluid is flowing an additional back pressure generated in the discharge piping, which needs to be compensated for by a further increase in inlet pressure to keep the valve fully open
* If discharging a conventional PSV into a closed system the back pressure present needs to be equally adjusted for
* The piping run from the protected piece of equipment to the PSV inlet can have a pressure loss of up to 3%. This also may need to be considered as it could tip you over a 10% or 21% overpressurisation of the protected piece of equipment.
Seems to me you are basically correct in everything you say, if you agree I can re-state your note and include your observations as follows in calculating your required area initially:
1) Assuming your required relief flow is exactly equal to the capacity of the valve, and 2) the orifice is sized to relieve that flow at a 10% overpressure, and 3) you reduced your inlet pressure to allow for a 3% drop in calculating the orifice area, and 4) you further adjust your dp across the orifice for the outlet built up plus superimposed backpressure in calculating the orifice area required, then all of what you say is exactly the case. If flow is less then you will not get full lift and will get less than 10% overpressure. 5) There is one more wrinkle to this - it assumes that sonic flow occurs at the orifice, this is where the flow correction factor comes into play if sonic flow is the case depending on the type of valve used and the total superimposed and variable backpressure. While superimposed backpressure affects the set pressure as you say, builtup and superimposed pressure must exceed a limit determined by the manufacturere before the factor is less than 1. If sonic flow is not the case we use another equation to determine the relief area.
Hope I did not mistate something (its easy to do when you try not to write a book), but if I did someone will probably pick it up.
When a PSV opens, the additional back pressure created is builtup back pressure. I would not say that builtup back pressure needs to be compensated by a "further increase in inlet pressure to keep the valve fully open".
If we are talking about a case where we are using 10% overpressure, then the builtup back pressure could be anything up to 10% of the PSV set pressure without any concern at all. Ignoring superimposed back pressure for the moment, the balance of forces on the valve disc should be such that
set pressure + allowable overpressure > spring force + builtup back pressure
and the disc remains in position (fully open). If builtup back pressure is greater than the overpressure (builtup>10%), the forces become
set pressure + allowable overpressure < spring force + builtup back pressure
and the disc will start to close. Then you must start looking at ways to reduce the builtup backpressure or its effects by increasing the outlet line size or using other than a conventional type valve. I don't think increasing the valve overpressure is a viable solution.
Now MarkkraM's last point about the 3% inlet loss is one I've always had some questions about but that could be a whole thread to itself.
To fully open a conventional PSV we need the force created from moving 10% above the set pressure. If the built-up back pressure is 10% does that not effectively cancel out the driving force applied against the spring to keep the valve fully open and thus it would start closing? Have I missed something fundamental regarding reseating of PSVs here?
There are two phenomena that help to keep the RV open:
1) disc area > nozzle area
As the disc begins to lift, fluid enters the control chamber exposing a larger area of the disc to system pressure. This causes an incremental change in force which overcompensates for the increase in spring force and causes the valve to open at a rapid rate.
2) momentum effect
As the disc begins to lift, the direction of the fluid flow is reversed and the momentum effect resulting from the change in flow direction further enhances lift.
Basically, the relief valve manufacturer must design RV such to ensure that the relief valve opens fully at setpressure + 10% even if built-up backpressure is 10% of setpressure. Ofcourse, replace 10% by 21% for fire case, see my original question...
I may have missed something in this, built-up back pressure refers to the pressure build up down stream of the relief valve. It only occurs when the valve in question goes into relief.
Assuming that your set pressure is above 15 psig, as long the built up pressure is less than ~40 % of the absolute relief pressure (critical flow conditions in the valve), there is little impact on the discharge flow or the accumulated relief pressure.
If you are discharging into a relief header and you have a constant back-pressure due to other valves relieving, then you need bellows so that the pop pressure of your valve is not modified.
The API requirements are very clear. I agree with pleckner and several others in this.
In my last post of 2/24, I incorrectly added the comment (fully open) to the inequalities that I presented. I believe I've seen these inequalities used to argue the point for saying it's okay for builtup backpressure < overpressure but they obviously won't work as argument that the valve remains fully open. Two different issues that I should not have tied together. By simple substitution into the inequalities of my last post, one would conclude that the spring force at full lift was equal to the set pressure which is not correct.
As for full lift, I believe what is missing in the inequalities is (as Guidoo points out) the momentum or rather kinetic energy effect. More appropriately then
set pressure + overpressure + KE >= spring force (full lift) + builtup back pressure
This would be needed to keep the valve fully open and from closing. Ironically, I was just recently involved in another thread where the KE effect was part of the discussion and I totally overlooked it here.
This may be deviating from the original thread somewhat, but now this has got me wondering about vendor's certified capacities. For a conventional type valve, vendor's typical give certified capacities at 10% overpressure. Generally, you can use their equations with no correction for back pressure as long as the back pressure does not cause subsonic flow. I believe relief valves carrying the ASME UV stamp are certified to ASME PTC 25. But PTC 25 outlines test requirements for pressure relief valves either when discharging to atmosphere (I assume this means little or no back pressure) or when discharging with builtup backpressure.
I'm assuming then that vendor certified capacities must be established per the tests when discharging with builtup backpressure for them to say their equations require no correction for backpressure as long as sonic flow exists.
The force for the spring is equal to spring constant x compression of spring (in this case). When the valve is closed, the compression of the spring (reduction in original spring length) results in a force exactly equal to the set pressure for the spring at which the valve will simmer as operating pressure increases - and then pop open due the large disk area (huddling chamber). This assumes no superimposed back pressure; which if present increases the opening pressure proportionally because it operates on the back side of the huddling chanber.
Now, since the spring force increases with further compression of the spring as it begins to lift, the huddling chamber must be present to assist in opening the valve; and the 10% overpressure is specified to obtain full opening of the valve and to guarantee accurate calculation of the required orifice size (ie - basis for equations used).
So much for balancing forces, valve stays open so long as relieving pressure on huddling chamber results in a force greater than spring force (Lets leave backpressure out of argument until a bit later). Note that the valve will be less than full lift as relieving pressure decreases until it closes at the reseating pressure the valve is set at. Also note that when the valve is at full lift, there is no further change in spring force since there is no further compression of the spring - there is only an increase in contact force of piston on valve body. If upstream pressure increases, contact pressure increases and flow increases.
Now lets talk about backpressure or should we say variable backpressure since all have agreed constant backpressure translates directly and is additive to the spring set pressure.
Next, for sonic flow occuring at the orifice. The combined total backpressure (superimposed and built-up) will determine if the capacity of the valve is affected and the vendor publishes charts for their valves which desribe this relationship (Kb). Its not as simple as if pressure drops to less than 1/2 the inlet pressure, further pressure reduction will not increase flow. While total backpressure reduction will not increase flow, increases in backpressure will reduce flow to less than certified capacity (specified at 10% normally). But allowable backpressure can be quite a bit higher than 10% without a derate in capacity and is related to how much is variable versus constant and the type of relief valve (balanced, conventional or pilot-operated). In general, however, we usually try to design for 10% builtup backpressure max with a conventional valve, although this can be exceeded, before we go to a balanced bellows valve. At the other extreme, backpressure might be as high as 30% for a bellows valve; or even 60% constant backpressure for a conventional valve relieving gas or vapor without a capacity reduction being required by the vendor. Use the vendors CHARTS! THey were developed to account for backpressure on a orifice at sonic conditions. Remember even though the capacity may be decreased, the orifice is STILL AT SONIC CONDITIONS. Why make it any more complicated? Use the vendors CHARTS!
I realise my misconception now. Once popped the pressure in the PSV chamber equalises. I had some pressure regulator concept going on in my head.
I hope my mistake has help clarification though. I was not trying to make things more complicated, just understand the reasoning behind certain rules. A better engineer is one who understands the rules they are following.
MarkkraM
P.S. We do not have vendor charts for many of our PSVs
Actually there are some so-called relief valves that do tend to operate like pressure regulators; many of the tubing type end relief valves made by NUPRO and CIRCLESEAL are examples. If you use valves like these - BEWARE! - because they are very much different than standard relief valves because most of them are not sized for a certified overpressure. If you set one of these valves at the MAWP its possible for the actual relieving pressure to be much greater than 10% or 21% for the required flow. So don't completely discard your previous opinions.
IF you have Crosby, or Farris or Consolidated-Dresser relief valve; contact a representative and they will be happy to give you a catalog with these charts; and also they have a software program available to assist in sizing calculations for free as well.
By the way, when we speak of standard relief valves we're talking about "D" (0.11 in2 orifice) orifice valves and larger.
