Anchor Bolts: B-212 Specification
Is anyone familiar with the anchor bolt specification B-212? I am unfamiliar with this material specification and its origin. A reference to the applicable specification and the bolt properties (Fy, Ft, Fu, Fv, etc.) is greatly appreciated.
RE: Anchor Bolts: B-212 Specification
The specification applies to an anchor bolt set that was installed during construction of a project in Turlock, CA. I think the bolt spec may be a Canadian or British standard??
Taro,
The application appears to be threaded anchor bolts with a 90 degree bend at their lower termination. From what I know of drill bit steel, it would be too brittle to permit such a bend. Do you know what the ANSI specification document number is?
Thanks for the posts.
