Recommended Spares List-Spreadsheet
Does anyone have or know where to find spreadsheet templates to produce spare parts lists for unit machines etc.for example if I build an Industrial Extruder and wish to produce a complete list of spare parts in a spreadsheet format where can i find examples.i understand excel well enough to produce a spreadsheet but i am looking for typical examples.
any help would be very much appreciated.
RE: Recommended Spares List-Spreadsheet
The spare parts inventory management includes the following information:
1. Part identification (name, number)
2. Vendor descriptions (could be several)
3. Inventor location (storeroom, bin, etc.)
4. Current inventory amount
5. Re-Order Point
6. Maximum inventory amount
The key to good spare parts inventory management is to ensure that the database matches the current inventory and that the re-order point is well coordinated with the spare parts delivery time. For example, if you use 1 spare part per week and the delivery time for the spare parts is 4 weeks, you will want to set the re-order point at no less than 5 parts. That way, 4 weeks later, you will receive your spare parts and still have one spare part in the inventory.
If you use Maximo, a lot of this will be done automatically, as the parts receivables, re-ordering and usage will be linked through the database. If you use a spreadsheet, you will need to manually coordinate those activities. This could become a difficult task if you do not control the contents of the spare parts inventory.
pj
2. You can use formulas and links with Reciepts and Issues.
1. start up
2. 1 year
3. 2 year
I use Excel's v-basic macros to search by a part number on the data base with the attached factors (that multiply by the original qty for the spare part qtys) and generate a spare parts list. It is current and fast. I even set up links and attach data sheets in PDF format to send to the customer. It takes a little while to setup but as you know, spare parts are worth lots of $.
Hope this helps
