Has anyone used the OpenDoc6 in SW 2003
I am trying to open a drawing Docuemnt, but cannot get it to work.
Here is the code:
Dim RetVal as Variant
RetVal = SolidWorks.Application.OpenDoc6(
"Drawing.slddrw", 3, 5, "", 0, 0)
Can anyone see the problem?  And yes, I have tried declaring RetVal as an object, as a ModelDoc2 and as a DrawingDoc.
John G.
RE: Has anyone used the OpenDoc6 in SW 2003
You have to declare RetVal as an object (as you described), but then you have to use the Set command:
Dim RetVal as Object
Set RetVal = SolidWorks.Application.OpenDoc6("Drawing.slddrw", 3, 5, "", 0, 0)
This is a MUST for all objects in VB, you have to use Set.
HTH,
Stefan
unofficial german SolidWorks helppage
http://solidworks.cad.de
Shareware, freeware, tools and macros
http://swtools.cad.de
