Automatic Wing Leveling
I vaguely recollect reading years ago about a wing leveling technique for model airplanes that corrected airframe roll attitude by measuring the differential output of earth gravity sensors in each wing tip.
Can anyone describe such a system suitable for model aircraft?
WDA
ballensr@adelphia.net
end
end
RE: Automatic Wing Leveling
Wouldn't it be simpler to fit your model with a proper dihedral? Just wondering. Cheers.
'Ability is 10% inspiration and 90% perspiration.'
Try something called FMA direct co-pilot which is basically an earth infrared sensor which can detect the level horizon as earth is always warmer.
model aviation may 2002 pg 78 had a writeup on and they were very enthusiastic about it.
rafeh1@yahoo.com
www.rdlabs.com
