ethanol-water-lithium chloride-chlorhydric acid mixture data
I'm modelling heat transfer in a lab reactor wherein there's a mixture of water(44%wt) ethanol(37%wt) lithium cloride(12%wt) and chlorhydric acid(7%wt).
As first step, i've made my calculation considering only the water-ethanol binary. Now, for accuracy increasing, i want to consider the ionic species too. Is there somebody knowing if there are data or correlations about this mixture thermal conductivity, viscosity, and heat capacity calculation (with temperature dependence)?
