UK pervaporation system company
Does anybody has any contact information of UK based pervaporation companies?
I heard that there is a company named SMART Chemicals doing pervaporation but I have no idea how to contact them, their website doesn't work anymore. Does anybody know what happen?
Thank you
PKT :)
Thank you
PKT :)
RE: UK pervaporation system company
In case you need more information on pervaporation you can also send an email to info@sulzermembranes.com - they also have an office in UK.
Good luck
Alternatively Sulzer chem tech would be your best bet (polymeric and silica ? based membranes) with the most track record.
I believe Velterop / pervatech may also be able to supply pervap membranes but these also have a limited reference base last I knew.
If you are after research contacts then I could suggest one or two names.
David G
I don't believe they are using the Smart equipment but still design and supply systems with externally supplied components.
