Marine Antenna Separation
Does anyone know of a good resource to find recommendations for the physical separation of marine antennae and associated equipment such as GPS, VHF, Inmarsat C, Fleet 77, HF, Marine Radar.
I am also looking for information on materials and methods that admit these frequencies while blocking others and lowering the radar cross section.
RE: Marine Antenna Separation
Suggestion: One practical way to approach this challenge is over Jane's Books on Navy Ships. Visit
http://www.janes.com
Click on Defence and then on Naval Forces
I've always found that other considerations (desired antenna height, field of view, mast structure weight limits, allowance for crane motion, limiting radhaz to crew, keeping rigging away from rotating antennas, etc) limit antenna placement so much that you just live with the fact that you simply have less than the ideal amount of real estate to play with. For example, at times I have had no other choice but to mount a GPS receive antenna within inches of a VHF whip, and VHF/UHF whips within a few feet of marine radars, and found no ill effects. At other times I have found RF interference problems due to emitters that were not even on the ship.
Unless you are involved in a major military project you're probably better off with a few rules of thumb (and perhaps some extra bandpass filters) than the cost and effort of developping an accurate RF model of the ship.
The most common naval technique of reducing radar cross section is to limit/eliminate corner reflectors within the ship's structure. Good examples are the Canadian CPF and French Lafayette designs. A great example is the Swedish Visby Class corvette. The Visby is also an example of enclosing all antennas within a single radome to reduce radar cross section. Another passive technique is applying RAM to high signature areas.
Suggestion: Another approach in antenna proximity layouts is to allow some priority in antenna functions (e.g. transmitter antenna) by antenna blanking. Visit
http://www.fas.org/man/dod-101/sys/ship/weaps/an_etc.htm
for: AN/SLA-10 (B) Ship  Video Mixer/Blanker
