Multiple rotated cuts using the same axis
Dear Folks;
If, during the course of making a 3d model in sw2001-2003 you have to make many rotated cuts using the same axis, can you choose a common axis or do you have to draw a new centerline every time you create a new sketch ?
Kind Regards
Adrian D
Kind Regards
Adrian D
RE: Multiple rotated cuts using the same axis
Hope that helps,
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
