Testing 575V Motor On 480V System
Can anyone point me in the direction of a formula or table calling out derating factors for running a 575V motor on a 480V system (both 60Hz)? I need to test run a machine before it ships, and I'd like some idea of the torque loss due to the lesser voltage.
Thanks in advance,
Tef
Thanks in advance,
Tef
RE: Testing 575V Motor On 480V System
Applying a pair of 480—120-volt 1ø transformers in an open-delta autotransformer configuration can provide 600V 3ø 3-wire for the equipment under test. Each 1ø transformer should be sized at 44% of the 600V-load kVA.
The heating from core losses will decrease, but let's neglect that (conservative) for simplicity.
To maintain thermal performance, you would need to derate to 480/575 ~ 83% of full load to keep current <= full load current.
As was mentioned by cbarn torque is also a factor. It will decrease ~ V^2 ~ 70%. That raises a question of whether the motor will stall during starting, and whether excessive heating will occur during starting.
I think that for a general purpose NEMA design B motor (breaqkdown torque 175%-250% of rated) driving a pump/fan load, there will be no stall during starting. However, the heating that occurs during the start will be increased and needs to be evaluated considering the load inertia, torque-speed characteristics, and starting method.
There has been a lot of discussion on starting heating on this forum. Here is something that I wrote on the subject.
http://www.geocities.com/pschimpf/RotorHeatingSymbols.htm
(Telec/(Telec-Tmech)) with 2s being the weighting factor, and s=1..s_operating being the averaging interval.
Total stator heating is roughly proportional to total rotor heating. Proportionality constant is R1/R2 (all quantities referred to stator side).
Sorry for going off on a tangent.
To be safe, I'll have the motor mechanically decoupled. I just need to spin them up to check operation.
Once again, this is simply a quick test. Commissioning will be on the specified 575V system.
