How do I delete multiple items in V5
If i have a bunch of lines or points that I want to delete, is there a way to select them all by filtering for points or lines?
Thanks in advance!!!
RE: How do I delete multiple items in V5
Use Edit + Search + Advanced Search + Select Type = Points or Lines and Search. Select the Result and delete them.
Cheers
Ganesh.N
ganesh.n@engg.tjc.co.in
Thanks!!
Another way to try is by typing "C:delete useless elements" in the command box.  This will highlight any elements that are not linked to the "solid". It also give you the option to de-select elements you would like to keep.
Rafy
