Erasing Center Marks
I am a new SolidWorks user and am making my first attempt at a drawing. I am running into a small but annoying problem regarding the display of center marks. When I inserted the initial view, the center marks were inserted as well. I have since found where to shut that option off so that it doesn't display them when the view is inserted. Now though I am stuck with the center marks that were inserted and I can't find out where, if anywhere, to delete, erase, or just make them go away. How do I get rid of them without having to reinsert the view?
Thanks for any help,
Ben
Ben
RE: Erasing Center Marks
objects...until you miss that is, then you gotta start
over...
You can also do a window and select all and delete all centermarks.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
from where you missed...Dang, I knew those filters were
good for something...hardly ever use them...until now...
Thx
