centrifugal valve suppliers??
Hi, I need some centrifugal valves. The centrifugal valve will have the same rotating axis with a rotating fan. When the fan is slowing down below a certain RPM, this centrifugal valve should close; and when fan is rotating above this RPM, this valve should in open state. Could anyone tell me some suppliers who can provide such valves? Thanks a lot!
RE: centrifugal valve suppliers??
thanks
Lamar Whitman
