EN-288-3 material groupings
Are the material grouping in EN-288-3 Table 3 the same or similar to ASME Section IX? If not, what material types are classified in group 1, group 8, and group 9? Also, does anyone know what the term "E-Hand" means as it relates to welding methods?
RE: EN-288-3 material groupings
Group 1 Carbon steel
Group 8 Ferritic and martensitic stainless
Group 9 Austenitic stainless.
E-hand means SMAW manual
Actual group descriptions as per EN 288 for info.
Nos in the bracket indicate P No as per ASME Section IX
Group 1 Steels with a minimum YS ReH</= 360 N/mm2 and with analysis not exceeding
C=0.24(0.25 for castings), Si=0.6, Mn=1.7, Mo=0.7, S/P=0.045, any other single element=0.3(0.4 for castings), All other elements total=0.8(1.0 for castings)
(P No 1)
Group 2 Normalized or Thermomechanically treated fine grain steels and cast steels with SMYS ReH>360 N/mm2
Group 3 Q & T and precipitation hardened steels except stainless steels
Group 4 Steels with Cr 0.75 max, Mo 0.6 max, V 0.3max
Group 5 steels with Cr 10 max, Mo 1.2 max
( P nos 3,4,5)
Group 6 Cr Mo V steels with Cr 12.2.max, Mo 1.2max, V 0.5max
Group 7 Ni alloyed steels with Ni max 10%(P No 9)
Group 8 Ferritic and martensitic stainless steels with 10.5%</= Cr </=30% ( P no 6 and 7)
Group 9 Austenitic stainless. ( P no 8)
Group 10 Austenitic ferritic stainless steels (duplex)( P no 10)
Where would group 2,3 and 6 fit in as per ASME Section IX?
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
Group 6 would be P5B gr. 2
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
