Manual vs Automated Valve Actuator?
I am looking to install a newco 8" class 300 gate valve operating as an isolation point on a 570psi hydraulic system. Is there a way to determine what the required opening torque at full differential pressure will be?
Basically, how do I know if the manual actuator will be suitable in this situation?
Thanks!
Thanks!
RE: Manual vs Automated Valve Actuator?
(713) 675-8631
