Beryllium-Copper vs Chromium-Copper
Currently, we are using chromium-copper for electrodes in our projection welding processes. Due to several "Quality" isssues, a question has arised about using beryllium-copper, instead. I understand that this is a more durable material, but could the lower conductivity of the beryllium-copper cause issue? Can anyone provide info on a comparison of the 2 materials.
Thank you.
RE: Beryllium-Copper vs Chromium-Copper
I can't give a definite answer (probably depends upon cycle & weld material parameters), but it seems worth testing the beryllium copper.  For maximum conductivity, try the ‘low beryllium’ C17500 alloy in the fully age hardened condition.  Possibly, a brief delay prior to applying current to lose some heat to the workpiece would allow use of a harder Be copper alloy.  Some material parameters:
Material       Alloy              YS, MPa      Hard.,HV  %IACS   Thermal cond.
0.7%Cr       C18500               530           125        80-85        324 W/m-K
low Be        C17500            650-870        230       45-52        200 W/m-K
Be copper C17200,C17400  965-1340   360-420    22-25        105-130 W/m-K
cast “    “    C82400               965           367          18            100 est.
Notes:  Properties for all alloys in precipitation hardened condition.
    The 0.8%Cr C18400 alloy has approximately the same values as C18500.
    ‘low Be’ is 99.6Cu-0.6Be-2.5Co in HT (TH04) Temper.
Data are from MatWeb.com, ‘Copper and Copper Alloys: Compositions and Mechanical Properties,’ CDA No. 36, 12th Edn., London (1964), and Metals Handbook, Vol. 2, 8th Edn., ASM, Metals Park, OH (1964).
Please report any results.
Thanks for the information...and the reply
