Simple Wide Angle Projector
I'm looking to build a $100 white light projector to project a pattern of lines.   The final image at an object distance of 5 feet must be at least 44" x 30".  The image should be close to being in focus and the object format is TBD.  The off-the- shelf projection lenses are too expensive and the focal lengths are too long anyway.  My light source is a 250W incandescent bulb.
RE: Simple Wide Angle Projector
Yes, it does have to be white light, or at least in the visible spectrum.  Laser light is not allowed, but thanks for the link.
