Design of heating pipes
I need to replace the heat pipes for a small apartment building. Each unit will be on a separate circuit for zone control. I have a procedure, but it seems very approximate.
Do you know of a reference that would help me determine the flows in each segment for a particular head pressure applied to the circuit?
RE: Design of heating pipes
The rule of thumb for selecting the head of the circ pump is the longest run in feet (use a table to convert fittings to equivalent feet of head loss) and multipy it by 0.06.
