hello .Can anybody help me with the sql syntax of searching
Ihave following problem.
in cells i have values
       critdate = Sheets("työ").Range("b1").Value
     critkonesk = Sheets("työ").Range("B2").Value
I suppose to use "dao"  and want to get information from access database
I know that access fields have  many sorts of format (txt,date,counter ,memo ,,,)
 i succed with text format  "critkonesk"
but the problem is "critdate"
tell me the syntax for such a matter
    Set rs = db.OpenRecordset _
    (" SELECT [KONE-pKORTTI].* " _
    & "FROM   [KONE-pKORTTI]" _
    & "WHERE ([KONE-PKORTTI].konesk LIKE '" & critkonesk & "') " _
    & "AND   ([KONE-PKORTTI].PVM    LIKE    '# critdate #'   ) " _
i am very greatfull for help
