In process drawings
In process drawings
I have no experience with pro E.
My designers tell me that Pro E won't let them create what I call an "in-process" sub-assembly drawing that shows pilot holes for rivets.
The drawings they give me show the final rivot hole size including the rivet countersink. What I need is a drawing showing pilot hole sizes or at least a drawing showing a small cross centerline at the location of each pilot hole. If I had that, then a note could be used to describe the pilot hole size. I would prefer a drawing showing the pilot holes i.e. a drawing that looks like the part will look right before it is matched to its mate and riveted. Can Pro E do this or are my designers right when they say Pro E won't let them change the final rivet hole size??
I am quite familiar with Autocad and can't imagine Pro E can't do what is an easy task in Autocad i.e. changing a feature size or just showing a location with centerlines.
I can't believe Pro E can't generate a drawing from a model that shows a part at any given stage throughout the process of manufacturing it. Am I wrong??
What do I need to know to show my designers (and myself)this can be done in Pro E
RE: In process drawings
We have done this effectively with cast parts that require machined mating surfaces, and drawings were required at both stages.
This worked quite well. Problem solved!! Thank you all for your help!!!!!
