air flow sensor
air flow sensor
Hi all,
I'm involved in building a medical device which requires a sensor to measure the flow of breathing. In similar devices, pneumotachometers are used. The problem is pneumotachometers are very sensitive with the gas's composition which is changed during the operation. The error is significant. Can any body recommend other types of sensors to measure the flow?
Thank you very much,
RE: air flow sensor
RE: air flow sensor
RE: air flow sensor
