Printing Mathcad to a PDF file
Whenever I print MAthcad models to a PDF file using Acrobat writer the symblos such as the "=" change to "?". Alos I get double"??" and reverse "?".
Is this a Nathcad bug or something to do with Acrobat?
Sharing knowledge is a way to immortality
RE: Printing Mathcad to a PDF file
TTFN
suggest you reinstall one or both of the programs.
TTFN
Mathcad 2000 works fine with Acrobat PDF.
However it will not work with earlier versions of Mathcad, such as Mathcad 6:
I work in Mathcad 6 and then read and save in Mathcad 200 then print to Distiller in Acrobat PDF format.
Ed
This method has proven to be the most reliable for me, with good results every time.
Dave
I guess this could be a potential problem with MathCad. Try change the font in your MathCad document.
SUGGESTION: Try changing the ":=" sign by "=", select MATH, OPTION, DISPLAY, and change the default for EQUAL. Print with Writer again and check if help.
Good luck.
First, set up a dummy ps printer in Windows, which will "print to file". It can be an Apple color laserprinter, or something like that. You don't need to have the printer, This is just a set of parameters to use when the print file is created.
1. Print from Mathcad to this dummy printer, which creates a file on disk. This will be a print file in the postscript language format.
2. Start Distiller, and use it to open the print file and create a PDF file. You can mess with job options for font embedding, etc, as much as you need. (tweak settings, distill file. check file, repeat as needed.) When you get it right, save the job options for future use.
You may need to tell distiller where the fonts are that Mathcad is using.
Anyway- this prevents hangups when printing, and allows quicker experimentation with job options, etc.
Good luck!
Jay
Jay Maechtlen
