motor stuck on
motor stuck on
I control a 36 V, 36 amps DC motor through a relay rated 80amps 36 volts, to close the relay it is a secondary circuit that i switch on 12v , works fine but motor keep running when i cut the 12 V on the relay.Do i have to put a capacitor somewhere to absorb energy on the the secondary circuit
Herve
Herve
RE: motor stuck on
RE: motor stuck on
If you have a heavy mass rotating when power is removed you will need to put a heavy load (low resistance) across the motor to slow it down.
Good luck! John D.
RE: motor stuck on
RE: motor stuck on
I beleive it is EMF built up as suggested, i will try resistor, i thought diodes or capacitors. I need it to stop instantly.
Herve
RE: motor stuck on
RE: motor stuck on
