POWER REQUIRED FOR SOLID AGITATOR
Dear Colleagues:
Any people Know that power I need add for move 1200 kg of solid in a tank of 1.250 mm of diameter. The weight of the shovel is approximately 175 Kg.Height is 1760 mm.
ANGLE OF POWER SHOVEL : 45ยบ.
ROTATION VELOCITY: 10 RPM.
I am grateful for advance
Jordi Beltran
RE: POWER REQUIRED FOR SOLID AGITATOR
I think it is best to built a small prototype ina certain scale to the gig one. Then measure the power needed in the small prototype and use model laws to calculate the power needed in big one.
Best Regards
Kari
Thank you for your response but I don't find the model laws to calculate the power for SOLID AGITATION. All the literarure and studies worldwide make about scale-up speak of liquids agitator.
Regards.
I would suggest you plough the intended material using your shovel pulling it with a hand spring weighter, so to measure the drag force. With that force, multiplied by the tangential speed of the central part of your shovel times the quantity of shovels involved could give you an initial idea. Besides you should take into account that solids transmit pressure direction wise, that is, your shovel should be turning as to lift the solid (never as to sink it) and you should add some power as you were actually lifting the whole column of solid up to its surface (in a liquid this is not the case)
My experience with sawdust have been challenging, due to its compresibility and the tree sap.
Take in account that all this power would turn into heat, and if it is a large quantity your mixer will become hot very fast.
sancat
