Help! Max1452 get sleep even on working, how hold awake
The OP-Amp Maxim 1452 begins to sleep not even by powerbreak
also in action powersupplyed. What must we do to hold working? It is used for a thread-tension Sensor with power-
measurement-thickfilmbridge.Must we connect a further part?
The unlock-pin is correct connected with 4.7kohm to ground.
Thank you for urgend help blueshirt
