Retreive data from different workbooks
Dear all,
I'm very new in VBA.I've been running on too little sleep and too much panic which has probably been the cause of my frantic cries for help on here.
 I have a question about using 2 workbooks. Worbook1 (activeworkbook)is my BOM. Worbook2 is my database. The logic is:
Book1: If colE is "U",pick ColA then goto BOOK2 search ColA in TableU for matching then retreive ColA,B,C,F to BOOK1 in Col G,H E etc...
IF ColE is "C",pick ColB and ColC then goto BOOK2 search in TableC, ColB,ColC for matching then retreive ColA,B,C,F in BOOK1 of Col G,H E etc...
Something like IF(E2="U",VLOOKUP(A2,'[C:\Test\BOOK2.xls]!Sheet1'TableU,False), IF(E2="C",VLOOKUP(.........
For this code below, I have problems:
1- Error 91
2- can retreive a little with a database have less 300 rows. The fact, my database have each sheets 50,000 rows
3- How the VBA can search like a wildcard ?? If in my BOM have a part 74HC00, I want the VBA can retreive all possile parts in database as
   74HC00A, 74HC00AN etc...
Sub BOM()
Dim rng, rng1, rng2, rngTable As Range
Dim wkbk
Set wkbk = Workbooks.Open("C:\Test\testing\Database.xls")
nmArray = Array("TableU", "TableQD", "TableC", "TableL")
Set OP_Ref = wkbk.Names(nmArray(LBound(nmArray))).RefersToRange
Set QD_Ref = wkbk.Names(nmArray(LBound(nmArray) + 1)).RefersToRange
Set Cap_Ref = wkbk.Names(nmArray(LBound(nmArray) + 2)).RefersToRange
Set L_Ref = wkbk.Names(nmArray(LBound(nmArray) + 3)).RefersToRange
Workbooks("testing.xls").Activate
Set rng = ActiveSheet.Range(Range("E15"), Range("E15").End(xlDown))
j = 15                ' Always starting at row 15
For Each cell In rng
    Set rng1 = Nothing
    Set rng2 = Nothing
    'Select Case UCase(Left(cell.Value, 1))
      Select Case cell
        Case "C"
            Set rng1 = Cells(cell.Row, "B")
            Set rng2 = Cells(cell.Row, "C")
            Set rngTable = Cap_Ref
        Case "D", "Q"
            Set rng1 = Cells(cell.Row, "A")
            Set rngTable = QD_Ref
        Case "L"
            Set rng2 = Cells(cell.Row, "E")
            Set rngTabe = L_Ref
        Case "U"
            Set rngTable = OP_Ref
        End Select
    Set rng3 = rngTable.Columns(1).Cells
    For Each cell1 In rng3
        iloc = InStr(cell1, rng1)
        If iloc = 1 Then
            For i = 1 To 19
                Cells(j, i).Value = cell1.Offset(0, i - 1).Value
                j = j + 1
            Next
        End If
        If Not rng2 Is Nothing Then
            iloc = InStr(cell1, rng2)
            If iloc = 1 Then
                For i = 1 To 19
                    j = j + 1
                Next
            End If
        End If
    Next
Next
wkbk.Close
End Sub
Thanks in advance,
