corrosion accelerated with use of block heaters ?
Any thoughts about increasted corrosion in the saltwater side of heat exchangers, of the typical marine diesel cooling system - that that uses block heaters to keep the vessel\s engines in a state of standby
RE: corrosion accelerated with use of block heaters ?
problems are in the casting area.
thanks .
Best of Luck
