Bonding Polyethylene & Polypropylene to Acrylic?
Does anyone know if there are adhesives for bonding Polyethylene & Polypropylene to Acrylic? Preferably anaerobic cure types.
RE: Bonding Polyethylene & Polypropylene to Acrylic?
Only adhesive I know about that will stick to untreated PP is PP based hot-melt.  YH America or Aica two manufacturers.
Howver, it is NOT considered to be a structural adhesive.
I think there may be a product that will do the job, it is acrylic based and is manufactured by 3M it may be worth a try
it was known as dp 400 but I when I used it but I think there is a new formulation and product code now.
3M Scotch-Weld Acrylic Structural Plastic Adhesive DP8005.
Remarkably, this actually bonds very well to polyolefins.  I've been testing a glued drop on PE film, and it has survived months in 180 F water.  It's a two part adhesive, 10:1 mix, and it contains micro-beads for gap registration. There's quite a bit of shrinkage upon curing.  Uncured, it flows slowly under gravity.
LiCl (Industrial) May 22, 2003
In addition to LiCl's contribution, I would like to add that even though there is sufficient mechanical bond using the DP8005, I have found (through recent testing) that in many applications, due to the micro-beads for gap registration, the bond is succeptable to "leakage" and doesnot promote a "sealable" bond for sealed bond applications of the 3M product.
Using primer "promoters" with some of the various 3:1 to 10:1 epoxies does show promise with polyolefins for a "sealed" bond application.
