calculating rotational torque limit based on press fit
I'm looking for information on calculating how much rotational torque and axial force a pressed fit steel hub on a solid steel shaft can withstand before slipping.
RE: calculating rotational torque limit based on press fit
Here are the formula you need:-
Torque that can be transmitted by an interference fit
without slipping:-
T= f*Pc*3.142*d^2*L/(2)
where f=friction coefficient
Pc=contact pressure between the two members
d=nominal shaft dia
L=length of external member.
to calculate Pc for a given interference use the formula:-
Pc=x/[Dc*[((Dc^2+Di^2)/(Ei(Dc^2-Di^2))+....................
((Do^2+Dc^2)/(Eo*(Do^2-Dc^2))-((Ui/Ei)+
Ui/Eo))]
where x = total interference
Dc=dia of the contact surface
Di = dia of inner member
Do= outside dia of outer member
Uo=poissons ratio for outer member
Ui=poissons ratio for inner member
Eo=modulus of elasticity for outer member
Ei=modulus of elasticity for inner member
This formula for Pc will simplify if the materials are the same.
Hope this helps
regards desertfox
Bill Corrigan
Thanks again,
Rustang
Rustang
to answer your last questions:-
Di = the inner dia of the
inner component ie:- a
tube, this is zero for
a solid shaft.
Dc = outside dia of the
inner member (o.d. of
shaft)
Finally for steel on steel (dry) the friction coefficient
around 0.25 but can vary below this depends on surface
finish , if you want to give a margin of safety use a friction factor around 0.15.
good luck
desertfox
