Welding symbolds in Solidworks
I'm a new user of SolidsWorks and I would like to know how I can draw a weld join or where I can get some help.
Thank you
Thank you
RE: Welding symbolds in Solidworks
"The attempt and not the deed confounds us."
Sorry about the last e-mail.
I'm trying to show weld beads in an assembly.
Having said that - click INSERT -> ASSEMBLY FEATURE -> WELD BEAD and follow the prompts.
You'll end up making a new part - that is the bead - mated into your assembly.
You do realize that the assembly MATES are what holds your pieces together, not a weld bead?
Consume mass quantities...
tatedeleteredj@usfilter.com
