SPRING BACK OF TUBES
I've come across numerous sites telling you how to calculate the springback in sheet metal when formed in a die. But my problem is this: I need to know if there is a formula for calculating the spring back of a length of tube when,
A:It is forced through a die to reduce it's O/D, and,
B:It is drifted to increase it's I/D.
I know how to calculate interface pressures between the tool and the tube, and I know how to calculate the change in length of the tube. It is just this formula that is eluding me. I can't find it in Roark's or Shigley either.
Can anyone point me in the right direction.
Conrad.
Conrad.
RE: SPRING BACK OF TUBES
K=EAL/2*B*BTRANS
E is modulus of Elasticity
A is Cross sectional area
L is length of the element
B is directional vector matrix (1, -1)/L
BTRANS is the transpose of B.
This simplifies to
K=EA/L* [1 -1]
[-1 1]
K is sort of the spring constant for the element.
If you have more than 2 nodes(properties of tube change through length you will need to prepare a global stiffness matrix.
