Shear through foundation walls at slab interface
How and where do you check for shear at a reinforced concrete foundation wall (resisting lateral soil pressure) and reinforced concrete structural slab interface?
Do you check a combination of regular beam shear and interface shear?  Can you count the vertical wall steel through the interface as shear resistance?  I typically use a 150 pocket so that the wall can bear on the wall.
|wall  |
|    __|____________\
|   |      SLAB            \
|   |_________________\
|       |  SHEAR CHECK?
|wall  |
THANKS
