Plumbing Calculation Tool
Does anyone know any tool for quick calculating fixture units and sizing the plumbing piping? I have seen once, it is like the "ductulator" for sizing the duct and very easy to carry and use.
Thank you in advance!
RE: Plumbing Calculation Tool
If you are sizing the water pipe, I use the code tables to get the fixture unit to flow rate conversion and then use the Bell & Gosset System Syzer to get the pipe size. I also sometimes use the Cameron Tables for the sizing.
Hope this helps.
Bill
http://www.sliderules.clara.net/collection/specialised/9918-mears-hyd.htm
