How do you select from multiple lines on top of each other in V5
I'm trying to delte a line that is under another line. Is there a way to choose which line to delete. In I-DEAS there is reconsider, you pick a line and hit reconsider and it runs through all of the availble lines. Thanks in advance!!!
I'm runng V5 on a unix HP
RE: How do you select from multiple lines on top of each other in V5
