ASME BOILER CODE TABLE UCS-23
I am trying to verify some calculations for (1) a flush plate replacement and (2) a nozzle insert into a 100 psi air tank at 300 deg F.  The Boiler Code refers to Table UCS-23 in several places concerning material properties.  I have not been able to locate this table and am beginning to suspect that UCS-23 is actually Sect II Part D.
Is this correct; if not, where can I locate the table.
RE: ASME BOILER CODE TABLE UCS-23
ASME SecVIII Div1 UCS-23 is on page 303. This is so you will look at the entire Code.
