WIND LOADS ASCE 7
WIND LOADS ASCE 7
WIND LOADS ASCE 7
Where do I find information on ASCE-7 wind loads @ 72 mph requirements for Calofornia? Is there a site on the web with that information?
Thank you
RE: WIND LOADS ASCE 7
JayZ:
This is probably to late to help you, but go to the ASCE.org site.  The current revision is ASCE 7-98.  California has probably adopted IBC 2000 which uses ASCE 7-98.  Amazon.com can also get references for you.  Also this is a standards book and not simply some data.
David J. Haley, PE
