Please help me compile this firmware
I have the following makefile in my project listed at the bottom of this post.  I need to compile this so it produces a motorola S-19 record, which I believe is already set as an option in the makefile.
I'm trying to compile the following way from the command prompt.
imakew -f makefile.mak
where imakew is a makefile compiler from ImageCraft, where I belive the engineers who wrote the code got their compiler.
But I get the following error:
"cd usb; make all
The system cannot find the path specified.
imakew.exe Error Code 1"
I tried using GNU make like this:
make -f makefile.mak
and I get a similar error message:
"cd usb; make all
MAKE: *** [usb_lib] Error 1"
What can I be doing wrong?  How can I compile this?? Please Help!!  I can provide more information if needed, thanks in advance.
Here is the makefile:
# -lc12p
CC     = icc12w
CFLAGS =  -DDEBUG -Ic:\\progra~1\\icc12\\include -e  -l -v -Wf-cpdon
LFLAGS =  -Lc:\\progra~1\\icc12\\lib -m -btext:0xc000 -bdata:0x0800 -bextcode:0x0.0x1FFFF -dinit_sp:0x0c00 -fmots19
OBJS   = main.o gpio.o eeprom.o soundbank.o version.o update.o security.o termio.o queue.o vectors.o
.c.o:
    $(CC) $(CFLAGS) -c $?
impro:    $(OBJS) usb_lib imcore_lib i2c_lib
    $(CC) -o impro $(LFLAGS) $(OBJS) -llp12p -lc12p -lusb -limcore -li2c -lspi
usb_lib:
    cd usb; make all
imcore_lib:
    cd imcore; make all
i2c_lib:
    cd i2c/asm; make all
clean:
    rm -rf *.o *.s19 *.lis *.lk *.s *.dp2 *.src *.lst *.mp *.i *.a
RE: Please help me compile this firmware
I assume you are trying to run this from windows no?
The command syntax shown here is done for unix. On unix, you can separate commands using ";". On dos, this is not feasible.
If I remember well, using gnu, you could try to replace the lines that way:
instead of:
     cd usb; make all
try:
     make -C usb all
Do the same for
      cd imcore; make all
