Spherical bearings/Rod ends in asemblies
Still working on modeling the rear end of a race car. Well, all those suspension bits are connected with rod ends, and balljoints. Modeling all of this is not a problem, but, I cna't seem to get it properly constrained such that I can move it all around, and check for interference at different levels of suspension travel. BAsically, wht's happening is that, when I use "move component" with the interference detection set to keep the parts form existing in the same space. This works to some extent, but sometimes, it fails, and the sphere part of the bearing will jump out of the race. There's probabally some simple solution to this, but I don't know what it is. I'd appreciate any help on this, or a lonk to a site explaining it, or....something :)
Chuck Boulware
Chuck Boulware
RE: Spherical bearings/Rod ends in asemblies
"The attempt and not the deed confounds us."
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
Chuck Boulware
When I am modeling mechanisms and activate the interference detection to simulate the kinematic and its limits, sometimes there are components jumping out of their interference restraint (but maintaining their mating restraints).
I think this is caused by to much speed on the mouse during simulation. Maybe, to catch the mouse, SW make big jumps on the iterations and skips those that would make it stop at the interference.
Try to do the simulation moving the mouse gently. A more complex simulation requires a slower mouse movement.
