Spaceball driver crashes in SW2003 SP1.0
When you have a file open in SW2003, and you try to open SW Explorer inside the program, your spaceball 4000 FLX driver does not work anymore. You have to reboot your machine to get it working again.
If you open SW E outside SolidWorks (start menu), there is no problem.
Does anyone now how to solve this problem? I use the next drivers:
3DxWare_v2-3-5_win32.exe
3DxSolidWorks_v2-2-1_win32.exe
RE: Spaceball driver crashes in SW2003 SP1.0
I would get the latest drivers. There are newer drivers @ 3DConnexion.
3D Xware 2.3.0 Build 6 and
Add in Driver 2.2.4.0
They are working "best yet" for me. However, I don't use explorer much.
Sean F
seanf@newing-halll.com
1 2 many l's in the addy :)
I have installed these new drivers. SW Explorer does not make it crash anymore. But it still does not run as it used to run with 2001plus. The problem when you start a new sketch, add a point and try to move it with your mouse, than use your spaceball = result: Crash with older drivers. With these drives this does not happen anymore. But the spaceball does not work anymore in sketches.
But I can live with it for the moment. But there are still a few problems which are anoying.
Hi there,
yes, we had a discussion some weeks ago in our german web forum and they figured out (with the help of API support and the developers of 3D Connexion) that there is a API related bug in SW2003:
SPR#162246 Crash dragging sketch line after calling ModelView::StartDynamics
So for 3D Connexion can't fix this the changed the driver so it wont crash SolidWorks anymore, but the backdraft is, that they just disabled this in their new driver.
So we (and they) have to wait for SolidWorks to fix the API and 3D Connexion to build another driver. Hopefully both of them do it as fast as they catched the previous crash issue.
HTH,
Stefan
unofficial german SolidWorks helppage
http://solidworks.cad.de
Shareware, freeware, tools and macros
http://swtools.cad.de
Again new drivers are available from the 3Dconnexion website:
- 3DxSolidWorks_v2-2-7_win32.exe
- 3DxWare_v3-1-11_win32.exe
I use at the moment:
- 3DxSolidWorks_v2-2-5_win32.exe
- 3DxWare_v3-0-24_win32.exe
I tested both new drivers. Unfortunately, when you have selected at least one entity in a sketch, the spaceball is still blocked untill you deselect all entities.
SolidWorks Explorer starts up quicker and without problems. But like older drivers the spaceball does not respond anymore after closing SWE. So I back graded to my current drivers again. What are those guys at 3Dconnextion doing? They have released a lot of drivers since the introduction of SW2003, but none performs like the drivers I had suitable for SW2001plus.
I wanted to provide all engineers over here with a spaceball, but thanks to the problems with these drivers IT has put the order on hold.
