Gusseting flat trusses w/ OSB
I'am actually a Entry Level BLDG Inspector and I've been presented w/ a Contractor who has completely gusseted some flat roof trusses which have been damaged in a fire resulting in a negative camber of at least 4", he has jacked up the trusses and applied 7/16' OSB across the entire span of the flat truss, My concern is: has the excessive rigidity imposed on the required deflection enough that the load transfer has gone from Vertical to a Lateral Shear imposing on the exterior walls?
RE: Gusseting flat trusses w/ OSB
If it was my problem, I'd insist on the involvement of a professional engineer. Get a report and an approval/disapproval.
Review your applicable code to understand how this works. In the UBC or IBC, Chapter 17 governs in-situ load tests. (see 1713 in the IBC 2000)
So basically, you can request that the contractor hire a structural engineer to validate the new "design" through calculations and his certification ... OR ... you should request that the contractor perform a load test to verify that he indeed meets the load carrying capability that is required.
Anything else would be putting the public at risk.
1.) Although I have not had the opportunity to investigate such a case, the American Plywood Association provides a clear step by step guideline for the calculations for plywood gusseted box beams. Worth looking into.
2.) Perhaps we are overlooking a consideration that may be more important: The deflection in the middle of the trusses might prevent proper drainage of the rainwater on the roof.
Keep in mind that firemen have their own opinions regarding what they like, or don't like in construction techniques.
