Measuring the length of a harness' wire w/non intrusive device
Thanks for your time. I have a harness routed from a PD Box down to the chassis framerail and all the way to the rear of a truck. I want to measure the length of that harness from the PD Box terminal to any given point half way through the chassis usig non intrussive method. The harness is protected with convoluted tubing and it contains about seven wires. I thought about using a device that would send a signal, or current through one of the harness' gauge 8 wire from the terminal at the PD Box and with a non-intrussive probe to register the signal at the desired location approx. 2 400 - 2,600mm and calculate an accurate length across a sample of 50 trucks.
This measuring system will be accurate enough to pass an MSA.
I will appreciate sharing your ideas and sugestions on how to do it?
Thank you
EA
Thank you
EA
RE: Measuring the length of a harness' wire w/non intrusive device
Why do you need to measure the distance of an arbitrary point along a wire?
More info = more help.
There is a product on the market that is used to detect broken wires and tell you roughly how far it is away from the connection point. I think it used a pulse transmitter and timed the reflection to calculate the distance or something like that. I used to have one for detecting a bad conductor in large bundles of control wires. I belive I saw the phone lineman using one as well for the same purpose. Unfortunately the name of the manufacturer or the trade name of the product escapes me at the moment. Check back in here later, as the name will surface in my brain and wake me up at approx. 3:00 AM on a Saturday when I could be sleeping in, as usual.
Quando Omni Flunkus Moritati
http://www.biddleinstruments.com/
Check out their Time Domain Reflectometers (TDRs). That is the device that pings the wire and tells you how far away the end is. They also have a small hand held device called a Cable Length Meter. Probably works on the same principal.
Oh, I just saw peebee's reponse. You beat me to it.
I guess I have killed too many brain cells. Must stop doing that soon.
Geologic displacement sensors work by having beads clamped onto the wire and any movement of the wire changes the reflection from the beads, giving a signal that can be interpreted for distance by virtue of the number of unrestricted beads in front of the change (I think). Those are very sophisticated versions of TDRs, (translate: expensive) but the idea is to have some sort of detectable anomally in the wire.
Magnetostrictive pulse sensors work on a similar principal and you could put a magnet over the wire at the measurement point, but I beleive that they require 2 conductors, and I'm not sure that anyone makes such a device as a portable measurement tool. This company makes a magnetostrictive LVDT (Linear Voltage Displacement Transducer) system called Gemco. Maybe they would be interested in helping come up with one. http://www.patriotsensors.com/
For my money I would try the TDR and experiment with finding a way to create an anomally along the length non-intrusively, (i.e. magnetic or inductive). But then again, its not my money!
If you can break and then reconnect the wire at the midpoint, the TDR will work fine. Actually, if there are connectors installed throughout the run, the TDR should be able to indicate the length to each connecter, all in one shot, even with all connectors connected.
If you can't break the wire, then jraefs other ideas make sense. Another unconfirmed idea: you might even get a TDR reflectance off a standard snap-on balun, or maybe one modified with a break/resistance/impedance in the balun magnetic circuit or "secondary".
ealvarado, can you give us some more insight regarding the type of wire & signal, the accuracy required, and the reason you want to check these lengths? What's the need to measure the length to any midpoint?
And just to make sure we're not ignoring the trivial solution, are these new or existing installations? Can you just mark the harness at 6" intervals prior to installation?
http://www.acterna.com/united_states/technical_resources/downloads/tech_notes/FDRdefine.pdf
etc. for more info.
