Head material.
Head material.
Head material.
    We are machining a DOHC head out of an aluminum billet.  Any suggestions as to what type of aluminum to use?
RE: Head material.
A billet is a worked solid, and therefore, made from wrought alloys.  Heads typically are cast, which requires casting alloys.  If you intend to use a wrought alloy billet, perhaps you can use the same material used for forged aluminium pistons - AA 2618.  Pistons are designed for similar conditions, therefore the performance should be similar.
